OSPF Area 0 - Campus versus WAN
Oct 12th, 2008
per
http://www.cisco.com/en/US/netsol/ns656/networking_solutions_design_guidances_list.html#anchor2
High Availability Campus Network Design-Routed Access Layer using EIGRP or OSPF
The design guide recommends changing the spf, lsa, and hello/dead timers to the msec on the Campus LAN but what about the WAN OSPf. I plan to use Area 0 on the WAN side. I don't think I need to tweak out the lsa,spf,hello,dead timers but would like to know what others have done.
Edison Ortiz Sun, 10/12/2008 - 16:31
Just like any design, the document provides recommendation on OSPF features. You must understand those features and apply them if needed. Not every design needs to be identical as there are a lot of variables thrown into each design. If you follow the design Best Practice from the document you've pointed out, you should be ok but also listen to the customer's concern - this is what makes you successful. If the WAN links are fast and reliable, then you can apply the same features as you would apply in the LAN.
HTH,
__
Edison.
