VG224 SCCP FAX-MODEM & RAS w/ATA186
Oct 12th, 2008
Hi, i am configuring 4 VG224 with SCCP and i have add these lines:
voice service voip
fax protocol pass-through g711alaw
modem relay nse codec g711alaw
Is that all that i have to use for the faxes and modems works or i have to configure something special on the ports that have a fax or modem.
Also i have to configure RAS, i have a CCM 6.x and ATA 186, do i have to convert the ATA to h.323 to make work with RAS. Do i need something more, i was thinking that the callmanager receive the call and pass it to the ATA as an H323 endpoint. Is that Ok? or i need something more ...
Thanks for your time,
Jose
Overall Rating: 4 (1 ratings)
pepito1983 Sun, 10/12/2008 - 16:39
If i don't have a Gatekeeper, can i configure the RAS? My scheme is below ...
PSTN -> GW -> CUCM -> ATA(H323) -> NETWORK
If i receive the call from the PSTN, i translate it into an extension that is routed by a Route Pattern to a Gateway h323 (ATA186). Does it works?
If no, can you please send me a link om how to configure that, thanks for your time.
Jose
gogasca Sun, 10/12/2008 - 16:43
  • Green, 3000 points or more
RAS is with a GK device so it allow or restric calls based on Bandwitdh basically
Your scenario works, if ATA is configure as H323 endpoint to CUCM, you can use Locations also.
For RAS you need GK
I dont have a link but CCO has a lot of info if you look deeper
pepito1983 Sun, 10/12/2008 - 17:05
Thanks, if i have a Gateway configure with MGCP (2 e1 and 8 Fxo) can i use it as Gatekeeper too (h323 commands so i can use RAS?
I also going to test my scenario with the h323 ATA endpoint without GK and try the RAS.
Jose
