Jagdeep Gambhir Mon, 10/13/2008 - 05:00
  • Red, 2250 points or more
In Solution Engine, A log file written into till it reaches 10 MB in size, Cisco Secure
ACS starts a new log file. Cisco Secure ACS retains the most recent 7 log files for each
CSV log. There is no option to create daily files in Solution Engine until we use Remote
Agent for Remote logging.That will give us an option for creating daily log files.
The links given below give details about the default logging and remote logging in
Solution Engine.
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_soft/csacsapp/csa
pp33/user/r.htm#wp952081
pp33/user/r.htm#wp952361
~JG
Do rate helpful posts
darpotter Tue, 10/14/2008 - 22:32
  • Silver, 250 points or more
...or you can use extraxi csvsync to pull down complete csv logs in bulk. When the appliance auto-purges old logs you'll already have them safely downloaded.
csvsync is a simple command line app that works with all versions/platforms of ACS.
http://www.extraxi.com/csvsync.htm
