Running WLANUI from a PC
Oct 12th, 2008
Is there a way to install and run the Wireless Management user interface from a PC. I have an 1841 and run SDM 2.5 from a PC but when I choose Wireless Application from the menu it loads and runs it from flash, which is horrendously slow. Also when trying to apply updates, I get HTTP 400 responses in most cases.
amritpatek Fri, 10/17/2008 - 14:27
  • Silver, 250 points or more
Make sure that for the Wireless management you need minimum memory required 13 MB (2,242,560 bytes), in addition to Cisco SDM memory requirements. And also need wlanui.tar file 2.13 MB.
CmdLineHell Fri, 10/17/2008 - 15:50
2,242,560 bytes is not 13MB, do you mean 13,631,488 bytes? And 13MB where exactly, I guess you must mean free RAM in the router itself, not flash? My 1841 is as follows:
#sh ver
Cisco 1841 (revision 6.0) with 222208K/39936K bytes of memory.
Processor board ID xxxxxxxxxxx
2 FastEthernet interfaces
1 ATM interface
1 Virtual Private Network (VPN) Module
1 802.11 Radio
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
#sh mem
Head Total(b) Used(b) Free(b) Lowest(b) Largest(b)
Processor 641A6060 158703520 42145568 116557952 115710732 115361308
I/O ED900000 40894464 4568348 36326116 36197504 36253052
So, what looks to me like bags of free memory there then. Are you suggesting I need to max the thing out at 384MB just to run the wireless GUI interface?
And incase you're refering to free space on the flash card ...
>sh flash
-#- --length-- -----date/time------ path
1 1038 Jul 27 2008 23:35:22 +00:00 home.shtml
2 112640 Jul 27 2008 23:35:24 +00:00 home.tar
3 26215040 Jul 11 2007 19:44:16 +00:00 c1841-adventerprisek9-mz.124-6.XE2.bin
4 2746 Jul 27 2008 23:35:22 +00:00 sdmconfig-18xx.cfg
5 527849 Jul 27 2008 23:35:24 +00:00 128MB.sdf
6 1505280 Jul 27 2008 23:35:46 +00:00 common.tar
7 6389760 Jul 27 2008 23:35:38 +00:00 sdm.tar
8 1697952 Jul 27 2008 23:35:52 +00:00 securedesktop-ios-3.1.1.45-k9.pkg
9 415956 Jul 27 2008 23:36:08 +00:00 sslclient-win-1.1.4.176.pkg
10 931840 Jul 27 2008 23:36:12 +00:00 es.tar
11 2242560 Jul 27 2008 23:43:44 +00:00 wlanui.tar
12 10072 Sep 20 2008 03:32:24 +00:00 SDM_Backup
23945216 bytes available (40075264 bytes used)
Wanlui.tar is present as you can see and loads, just extremely slowly as the WEB server in IOS appears to extract content for each HTTP request from the tar file afresh. Plenty of free space here too.
SDM can be installed either on a PC so it loads from there instead of running like a dog from flash via the router. I run it from a PC but the wanlui stuff still appears to load from flash.
My question is whether anyone has found a way to install and run the content of wanlui.tar on a PC so it loads from there in the same way as SDM itself. It might then be usable (although the 404's it generates when you try to post updates do not bode well).
A more pointed question might be why after all this time for a router in this market segment, Cisco hasn't replaced this ridiculous bug ridden java rubbish with a decent GUI front end that actually does what it says on the tin. Let's just tell it like it is shall we ...
SDM is complete pants so we all have to resort to reading masses of incoherent PDF files and typing half of war and peace into some god awful 40 year old dumb terminal emulation. Time to pull your finger out guys and get with the 21st century, the competition is leaving you in the dust.
Trending Topics - Security & Network
