FXO Card takes long to release a call.
Oct 12th, 2008
Am experiencing a problem with a Callmanager Express that i recently deployed.The problem is after a call is made,the FXO take a while to terminate the call-it shows the call as being active for some time though the call has long been completed,this is the output of the 'show voice call status'
SST_VOICE_GATEWAY#show voice call status
CallID CID ccVdb Port DSP/Ch Called # Codec Dial-peers
0xD815 891 0x65ABB2AC 0/2/2 0/1:1 *8076910095 g711ulaw 0/8071
0xD817 991 0x65AAE1E4 0/1/0 0/1:2 *8052783000 g711ulaw 0/805
2 active calls found
Please keep in mind that all the calls above have long been completed.
Sometimes when a number of calls are made-the FXO cards 'hold' on to the call for sometime till the FXO cards are reset-this is sometimes done by rebooting the router for the FXO cards to be reset.
These are the timers set on the FXO cards:
voice-port 0/0/3
cptone GB
timeouts interdigit 4
timeouts call-disconnect 2
timeouts wait-release 2
connection plar opx 101
impedance complex2
The IOS that the router is using is:
How can this problem be solved?
Any suggestions are welcome.
