Security on Aironet 1300 bridges
Oct 12th, 2008
I am a newbie on this fourm. I required your suggestions and recommendations. I have aironet 1300 bridges. I want to connect them in point to multipoint envt.
I want to have one root bridge and rest as non root bridges. But i want to implement authentication of non-root bridges through root bridge. Please suggest what is the latest and strongest authentication and security protocols that i can use. Please i am looking for an early response.
carenas123 Fri, 10/17/2008 - 13:19
  • Silver, 250 points or more
EAP Authentication type provides the highest level of security for your wireless network. By using the Extensible Authentication Protocol (EAP) to interact with an EAP-compatible RADIUS server, the root access point/bridge helps another access point/bridge and the RADIUS server to perform mutual authentication and derive a dynamic unicast WEP key. The RADIUS server sends the WEP key to the root access point/bridge, which uses it for all unicast data signals that it sends to or receives from the non-root access point/bridge. The root access point/bridge also encrypts its broadcast WEP key (entered in the access point/bridge's WEP key slot 1) with the non-root access point/bridge's unicast key and sends it to the non-root access point/bridge.
Tasneem Fazal Fri, 10/17/2008 - 22:15
Thanks for your reply. can we use WPA2 istead of WEP here for encryption and EAP for authentication. Is WPA2 is supported on 1300 bridges.
