IOS question
Answered Question
Oct 12th, 2008
I am going to upgrade the IOS of CAT 3750. I search cisco wbe site but there is no any related step and procdure. Anyone has the idea (steps) to upgrade the CAT IOS?
rdgs
Correct Answer by Giuseppe Larosa about 8 years 9 months ago
Hello Anita,
below a link for IOS upgrade for a stack of switches.
If your switch is a standalone switch follow the item:
manual (.bin file)
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00804799d7.shtml
use flash: to address the flash file system in a stand alone switch
Hope to help
Giuseppe
Overall Rating: 5 (2 ratings)
Correct Answer
Giuseppe Larosa Sun, 10/12/2008 - 23:23
  • Hall of Fame,
    Founding Member
Hello Anita,
manual (.bin file)
Hope to help
Giuseppe
sateeshk10 Sun, 10/19/2008 - 13:00
Sorry to intrept you..
I have small problem with my stack switches..When i typed show swtich its showing 3 switches..But when i type show flash command its showing flash and flash1 only how abt third switch flash as i need upgade the IOS. pls help me..
sateesh
mlitka Sun, 10/19/2008 - 13:24
Sateesh -
You can use the 'remote' commmand to run commands on the remote switch, if you want to verify that the image was copied to the flash of your third switch.
If you use the download-sw command the IOS should automatically copy the image to each of the switches.
Giuseppe Larosa Mon, 10/20/2008 - 05:18
  • Hall of Fame,
    Founding Member
Hello Sateesh,
try to use flash1:, flash2: flash3:
SW-NY-C-1#dir flash1:
Directory of flash1:/
2 -rwx 52779 Oct 1 2008 09:10:07 -04:00 config.text
90 -rwx 10546229 Oct 1 2008 07:48:07 -04:00 c3750-ipservicesk9-mz.122-44.SE2.bin
5 drwx 128 Oct 1 2008 07:33:48 -04:00 c3750-ipservices-mz.122-25.SEB
92 -rwx 27 Oct 1 2008 09:10:07 -04:00 private-config.text
442 -rwx 1164 Aug 29 2008 21:53:50 -04:00 vlan.dat
443 drwx 0 May 19 2005 10:44:13 -04:00 crashinfo_ext
444 drwx 128 Aug 29 2008 21:53:55 -04:00 crashinfo
4 drwx 64 Oct 1 2008 07:29:10 -04:00 c3750-ipservices-mz.122-25.SEB1
15998976 bytes total (3792896 bytes free)
SW-NY-C-1#
SW-NY-C-1#cd flash1\c3750-ipservices-mz.122-25.SEB
%Error statting flash:/flash1\c3750-ipservices-mz.122-25.SEB (No such file or directory)
SW-NY-C-1#
SW-NY-C-1#
SW-NY-C-1#
SW-NY-C-1#dir flash2:
Directory of flash:/
2 -rwx 10546229 Oct 1 2008 07:52:27 -04:00 c3750-ipservicesk9-mz.122-44.SE2.bin
3 drwx 128 Oct 1 2008 07:34:14 -04:00 c3750-ipservices-mz.122-25.SEB
441 -rwx 1164 Jul 31 2008 22:57:31 -04:00 vlan.dat
5 drwx 64 Oct 1 2008 07:32:23 -04:00 c3750-ipservices-mz.122-25.SEB1
9 -rwx 52779 Oct 1 2008 09:10:06 -04:00 config.text
6 -rwx 27 Oct 1 2008 09:10:06 -04:00 private-config.text
15998976 bytes total (3796992 bytes free)
SW-NY-C-1#
SW-NY-C-1#dir flash3:
Directory of flash3:/
3 -rwx 10546229 Oct 1 2008 07:57:18 -04:00 c3750-ipservicesk9-mz.122-44.SE2.bin
5 -rwx 27 Oct 1 2008 09:10:07 -04:00 private-config.text
6 -rwx 1164 Jul 31 2008 22:57:31 -04:00 vlan.dat
7 drwx 128 Oct 1 2008 07:35:03 -04:00 c3750-ipservices-mz.122-25.SEB
4 drwx 64 Oct 1 2008 07:32:46 -04:00 c3750-ipservices-mz.122-25.SEB1
SW-NY-C-1#
About the procedure:
I've used
http://www.cisco.com/en/US/customer/products/hw/switches/ps5023/products_configuration_example09186a00804799d7.shtml
the operations are all done from the current master:
copy tftp: flash1:
then
copy tftp: flash2:
then
copy tftp: flash3:
But if you really don't see the flash of the two slave routers there is some problem
Hope to help
Giuseppe
sateeshk10 Mon, 10/20/2008 - 11:08
Thanks for info...I want to use .bin file upgradiation as i am comfortable with tar file..
1) I have to set the bootsytem like
boot system switch all flash:/image right
If i set like that this will change all switches boot system right??
2) I want to reload the switches manually ?? is there any single command to reboot all the switches...
Its very urgent..
Sateesh
Giuseppe Larosa Mon, 10/20/2008 - 11:19
  • Hall of Fame,
    Founding Member
Hello Sateesh,
1)
yes each switch sees its own flash as flash:, it is the master that addresses via TFTP the slaves' flashes as flash2: , flash3:
2) once you have checked the bootvar on all switches (follow the link in previous post for detailed steps) you just need to issue the reload command on master: automatically all of them will be and should load the new image.
I advice you I had problems so setup console connections to all of the switches for safety.
And if something goes wrong and a switch is stucked in rommon you can only use xmodem.
Hope to help
Giuseppe
sateeshk10 Mon, 10/20/2008 - 12:58
Due to some issues my switch gone to ROM MON From ROM mode can I boot my switch with old IOS..
like boot flash:\file name ..is there any command like that..?? or I need to upload the IOS trgh XMODEM ??
sateesh
