IPS 4240 -email arlert configuration and Which mode
Oct 12th, 2008
hi
My topology
1)
Internet-router(2ISP terminated in Single Router-two different Firewall-(ASA5510 and PIX 515e)-->inside interface connected in IPS4240--->From IPS to L33750 Switch.
Is right place to put IPS4240 and tell me IPS in which mode(inline or Promiscous).
2) I am able to see log in IPS 4240, i want to configure IPS alert to my mail id , where i need to start the configuration.? pl advise
thanks
Karthik
smalkeric Fri, 10/17/2008 - 11:46
Email alert configuration is not supported in IPS/IDS.
I think you can configure in promiscuous mode as Customers requiring promiscuous mode (non-inline) deployments are encouraged to migrate to the Cisco IPS 4240 Sensor, which supports up to 250 Mbps of IPS throughput.
The below URL helps to configure IPS 4240 in promiscuous mode:
http://www.cisco.com/en/US/docs/security/ips/5.1/configuration/guide/cli/cliInter.html#wp1033699
mkkeyan Mon, 10/20/2008 - 00:23
Thanks for the reply.i found that IOS 6.1 it is possibe, using CISCO IPS MANAGER EXPRESS.
thanks
Karthik
