WLC - How to backup configuration file by scp ?
Actually in my company, we backup configuration file (running-config & vlan.dat) by SCP with an automatic script which just download these two files for our Cisco Devices (router, switches, AP, ...).
I would like to do the same backup on the Wireless Lan Controlle 2106 v5.1.
Could you tell me if it's possible to backup files located on the WLC by SCP?
I don't found a command like "dir flash: ; dir nvram: ; ...".
Thomas Rueb Wed, 01/04/2017 - 05:17
Hi Vlad,
This link doesn't provide information on how to initiate file transfers FROM the server - at least I couldn't find any. Is there a way to do as mentioned, or do I always have to initiate the transfer FROM the controller?
Thomas
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
