NM-2CE1T1-PRI
Answered Question
Oct 13th, 2008
This card NM-2CE1T1-PRI does it support voice?I want to activate voice on it but it does not work.How do i do that ?
Correct Answer by Rob Huffman about 8 years 7 months ago
Hi Kolawole,
This module is "Data Only" and does not support voice. Have a look at the description for the NM-1CE1T1-PRI;
Module as "Data Only",
The versatility of Cisco 2610-51XM, 2800, 2691, 3660, 3700 and 3800 series routers is demonstrated by their broad support of E1/T1 connectivity and Integrated Services Digital Network Primary Rate Interfaces (ISDN PRI). Customers continue to deploy E1 and T1 circuits for Wide Area Network (WAN) connectivity, ISDN dial-backup, and digital modem termination in the Power Branch Office Environment. Cisco now makes it possible to terminate T1 and E1 PRI connections in a single network module. Available in single and dual port models, the NM-1CE1T1-PRI and NM-2CE1T1-PRI cards coupled with Cisco 2610-51XM, 2800, 2691, 3660, 3700 and 3800 Series routers, enhance and simplify customers' WAN connectivity options
The Cisco E1/T1 ISDN PRI Network Module's integrated channel service unit (CSU) provides direct connection to the Telecommunications network, thus allowing customers to consolidate customer premises equipment (CPE). This provides multifunction dial access aggregation, routing functionality, VPN and firewall security, and other capabilities right inside the Cisco router in power branch office environments. Both the 1-port and 2-port versions offer support for balanced and unbalanced E1 connectivity and conform easily to customers' specific applications.
The Cisco E1/T1 ISDN PRI network modules also supply connectivity for internal digital modems in the Cisco 3660, 3700 and 3800 series routers, with connectivity options for PRI, T1 channel associated signaling (T1-CAS), and E1-CAS R2 signaling. This provides for a high concentration of V.92-compatible modems, while still allowing expandability for other critical services.
FEATURES AT-A-GLANCE
Cisco IOS Software configurable for T1 or E1 operation
Balanced or unbalanced E1 termination in the same module
Integrated CSU/DSU (channel service unit/data service unit) per port
Full or fractional E1/T1-can be fully channelized
***Supports PRI for data, T1-CAS, and E1-CAS R2 signaling
E1 unframed and framed modes (G.703/G.704) available
Interoperates with NM-xDM digital modem network modules
Bantam (tty) jacks for easy network monitoring
V.54 loopback compatible
Supported on Cisco 2610-51XM, 2800, 2691, 3660, 3700 and 3800 Series routers
Online insertion and removal (OIR) supported on Cisco 3660 3745 and 3845 routers
On-board expansion slot for future technologies
From this doc;
http://www.cisco.com/en/US/products/hw/modules/ps2797/products_data_sheet09186a0080189f95.html
See also, this good doc;
Relevant Interfaces and Modules
http://www.cisco.com/en/US/products/ps5854/products_relevant_interfaces_and_modules.html
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Mon, 10/13/2008 - 04:32
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Kolawole,
From this doc;
Hope this helps!
Rob
kolawole1 Mon, 10/13/2008 - 06:50
Thanks Rob.I MISTAKENLY bought that card hoping it could support voice.
I was able to set up auto attendant with CUCM 4.1 integrated with unity express 2.3 (without the need to set up translation rules)I am using mgcp.
Now I would like calls to autoattendants to be transfered to the user's voicemail if the user is absent.How this could be done?
