Secondary credentials fail in CS
Oct 13th, 2008
Hi everyone,
I have a question on a credential issue we encountered at a customer site during implementation of CWLMS 3.0.
Customer applied 2 sets credentials for initial discovery. As expected some of the devices were found but failed on the first credentials. But the secondary set seems not be tested if primary fails.
Is this corect behavior or are we interpreted default credentials wrong?
Joe Clarke Mon, 10/13/2008 - 07:00
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Secondary credentials do not apply to Discovery. If you need to add multiple SNMP credentials for Discovery, you must do that within the Discovery settings.
Jeroen Tebbens Tue, 10/14/2008 - 00:34
It's not about snmp credentials. It's about username/password/enable credentials. When first set (PRIMARY) fails, it should try the secondary.
/Jeroen
Joe Clarke Tue, 10/14/2008 - 08:29
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
So you're talking about RME, then? If so, you must tell RME to use secondary credentials under RME > Admin > System Preferences > RME Secondary Credentials.
