Installation Error - CUCM release 6.1(2)
Oct 13th, 2008
we started a fresh installation, but it failed giving below error msg:
"The installation has faild and must be restarted to recover from failure. You may dump diagnostic information at this time to a USB storage key. Would you like to dump diagnostic information? "
I already restarted the server[MCS-7816] many times and each time the same error msg appears.
Kindly assist on above at the earliest..
S.Al Zaabi
renier.dewitte Mon, 10/13/2008 - 02:38
i had the same problem
i just started an new installation and the problem was solved no error.
did you manual restart you server?
sendia.alzaabi Mon, 10/13/2008 - 02:44
Thanks for your reply. yes i already restarted the Server, but no luck. the same error appears again and again.
renier.dewitte Mon, 10/13/2008 - 02:49
I've got that problem because is manual restart my server after the installation.
then I started a new installation , installation started , I went home and the next morning I could login to cucm.
sendia.alzaabi Mon, 10/13/2008 - 02:54
actually, this problem occurred during the installation. later i had to restart the server as instructed in the error msg, but with no use!
deannamck Fri, 03/13/2009 - 08:25
I have the same issue but with CUCM 7.0(1). How was this issue solved?
