Contact Center: Outbound option : connection between Agent and Customer fai
Oct 13th, 2008
Dialer has list of calls. Agent gets notification to accept call on phone (soft key?).
After accepting the call, call should get established however this is failing. Once
a phone is in this status it keeps on failing.
Administrator moves the phone to different device pool and back to recover from this or reseting the phoen helps but after some times this issue keeps repeating-
Intermittend issue, no pattern seen.
All 7940 phones. Firmware 8.0(4)
CallManager 4.1(3)SR4b
prakashj Mon, 10/13/2008 - 01:41
followed all the below steps but still the problem persists and randomly happening.
you follow the correct procedure to do Cisco Outbound Option Installation
1. Joining the IPCCDialer to the Domain
2. Installing the Outbound Dialer
3. Machine Wizard/Deployment Wizard (for IPCCDialer)
4. Configure Outbound Call Types
5. Configure Outbound Dialed Numbers
6. Configure the Outbound Skill Group
7. Enable the Outbound Option Call Variables
8. Outbound Option System Options Configuration
9. Outbound Option Dialer Configuration
10. Outbound Option Import Rule Configuration
11. Outbound Option Query Rule Configuration
12. Outbound Option Campaign Configuration
13. Enable Outbound Mode for Cisco Agent Desktop
14. Configure CallManager Device Pool
15. CallManager Bulk Administration Tool (BAT)
16. Adding a CTI Route Point for Outbound Abandon
17. Create an Outbound Administrative Script
18. Create an Outbound Reservation Script
19. Create an Outbound Abandon Script
20. Create the xx_Survey.txt Data File
21. Testing the Outbound Option
prakashj Mon, 10/13/2008 - 22:04
I have got the exeact logs when the problem happens from the Dialer PG.
it is due to the MR Reservation timout , Pls advive how to change this parameter in dialer..
Below are the logs..(taken during the issue time)
16:27:01 Trace: (DD) Media Routing Reservation Timed out for port: 000
16:27:02 Trace: MRTask::ProcessNewTaskFailureEvent: Received NACK for NEW_TASK
DialogueID=506, SendSeqNo=-1, ReasonCode=ICM media routing has been disabled
16:27:03 Trace: (DD) Media Routing Reservation Timed out for port: 001
16:27:05 Trace: (DD) Media Routing Reservation Timed out for port: 002
Best Rgds,Abraham
974-5824202
shayonasul Tue, 10/14/2008 - 11:21
  • Bronze, 100 points or more
Did you configure the dialer ports on CM with appropriate CSS permissions for outbound dialing?
HTH,
Sulabh
