Issue with Domain Resolution
Oct 13th, 2008
Hello Folks,
I have tried the next to enable the domain name resolution, but it doesn't work:
ip domain-lookup
ip name-server xxx.xxx.xxx.xxx
ip name-server yyy.yyy.yyy.yyy
If I send a ping like FQDN (example: www.cisco.com), there is not domain resolution. Appear the next:
Translating "www.cisco.com"... domain server (xxx.xxx.xxx.xxx) (yyy.yyy.yyy.yyy)
% Unrecognized host or address, or protocol not running.
Where the X address and Y address are the DNS of my ISP.
Could somebody help me please?.
Thanks in advance!!
satish_zanjurne Mon, 10/13/2008 - 04:52
  • Silver, 250 points or more
1.Ensure the router can reach the DNS server. Ping the DNS server from the router using its IP address
2.Use these steps to ensure that the router forwards the lookup requests:
1.Define an access control list (ACL) that matches on DNS packets:
access-list 101 permit udp any any eq domain
access-list 101 permit udp any eq domain any
2.Use the debug ip packet 101 command.
Note: Ensure that you specify the ACL. If you enable the debug ip packet command without an ACL may produce a large amount of output to the console and cause the router to reload.
3.Ensure you have the ip domain-lookup command enabled on the router.This command is enabled by default , but still check it.
HTH...rate if helpful...
elias.manchon Mon, 10/13/2008 - 05:10
Hi Satish,
The first step fail. I cannot reach any ip address with Ping, Then I have disabled the access-list on my ATM interface and the same problem.
What can be happen?
satish_zanjurne Mon, 10/13/2008 - 05:31
1.Are you able to access internet from behind the router ?
2.Looks like routing issue.
3.Are you able to ping the ISP side IP Address from router ?
elias.manchon Mon, 10/13/2008 - 06:38
Yes, this is the configuration:
Current configuration : 2011 bytes
! Last configuration change at 16:08:56 UTC Mon Oct 13 2008 by admin
! NVRAM config last updated at 09:33:19 UTC Mon Oct 13 2008 by admin
version 12.4
no service pad
hostname XXX
boot-start-marker
boot-end-marker
enable secret 5 XXX
no aaa new-model
dot11 syslog
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
ip name-server XXX.XXX.XXX.XXX
ip name-server YYY.YYY.YYY.YYY
username zzzz privilege 15 password 0 cccc
no crypto isakmp enable
archive
log config
hidekeys
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
hold-queue 224 in
interface ATM0.1 point-to-point
bandwidth 2016
ip unnumbered Vlan1
ip access-group 101 in
pvc 8/32
encapsulation aal5snap
protocol ip inarp
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
ip address KKK.KKK.KKK.KKK 255.255.255.192
hold-queue 100 out
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 ATM0.1
no ip http server
no ip http secure-server
access-list 101 permit ip host XXX.XXX.XXX.XXX host KKK.KKK.KKK.KKK
access-list 101 permit ip host YYY.YYY.YYY.YYY host KKK.KKK.KKK.KKK
access-list 101 deny ip any any
no cdp run
control-plane
line con 0
exec-timeout 120 0
password ccc
no modem enable
stopbits 1
line aux 0
line vty 0 4
access-class 23 in
exec-timeout 120 0
password ccc
login local
length 0
scheduler max-task-time 5000
end
Thanks Again!!
satish_zanjurne Mon, 10/13/2008 - 07:10
From any windows client behind the router on the command prompt see whether you are able to resolve google.com or cisco.com ??
"nslookup google.com"
"nslookup cisco.com"
elias.manchon Mon, 10/13/2008 - 07:42
From any windows client, the nslookup command and the ping command works fine.
From router console neither of them works.
Greetings!!
elias.manchon Mon, 10/13/2008 - 08:11
The problem of ping, could be the command on ATM 0.1 interface?:
bandwidth 2016
ip unnumbered Vlan1
pvc 8/32
protocol ip inarp
This is the only configuration strange on this router.
elias.manchon Mon, 10/13/2008 - 07:14
version 12.4
no service pad
hostname XXX
boot-start-marker
boot-end-marker
enable secret 5 XXX
no aaa new-model
dot11 syslog
ip cef
archive
log config
hidekeys
interface ATM0
no ip address
hold-queue 224 in
bandwidth 2016
ip unnumbered Vlan1
pvc 8/32
protocol ip inarp
interface Vlan1
hold-queue 100 out
no ip http server
no cdp run
control-plane
line con 0
exec-timeout 120 0
password ccc
no modem enable
stopbits 1
line aux 0
line vty 0 4
access-class 23 in
exec-timeout 120 0
password ccc
login local
length 0
end
Thanks Again!!
