allan.thomas Mon, 10/13/2008 - 03:26
The error is displayed because CDP is being disabled on the Phone within CUCM, the default is enabled. Is this correct, do you intend to disable CDP?
The current PC and switch port CDP values are shown on the Settings menu.
Have you tried adding the Phone without disabling CDP?
Allan
sheerazkhatri Mon, 10/13/2008 - 03:30
From your attachment, it seems you have disabled CDP on the switchport on which phone is connnected. You need to enable CDP. Goto interface on which phone is connected and type cdp enable command... It should resolve your problem.
Sheeraz
Rob Huffman Mon, 10/13/2008 - 04:50
Hi Selome,
There are two Bugs associated to this problem. Have a look;
CSCsi52910
All IP Phones are connected to Cisco Switches and have CDP enabled .
It does not matter If the third generation IP Phone is registered or not registered with call Manager.Message pops up on both the cases for all third generation IP Phones.
7940,7960 Phones does not have this problem.
Status
Fixed
Severity
Last Modified
In Last 3 Days
Product
Cisco Unified Communications Manager (CallManager)
Technology
1st Found-In
4.2(3)
Fixed-In
4.3(1.62)
4.3(1)SR1
4.2(3)SR2a
4.2(3)ES32
4.1(3)SR5
4.1(3)ES112
3.3(5)ES62
Related Bugs
CCMAdmin - CDP pop-up warning whenever phone updated
Symptom: CCMAdmin pops up CDP warning messsages whenever phone (7941, 7970 etc) is updated. Conditions: When phone is updated, with or without changes to the CDP flags. Workaround: Click ok on each warning message Further Problem Description:
CSCsi88338 Bug Details
Headline CCMAdmin - CDP pop-up warning whenever phone updated
update , modification on any Third generation IP Phones , 7941/7961/7970 , From CCM Administration page after updating 4.2.3 ES26 pops up Error message
"Cisco Discovery protocol CDP : switch Port: Warning! CDP should only be disabled on the Network Port if the phone is connected to non-switch.
For further details , consult the call Manager Administration guide.
Note If you clicked update just prior to receiving this message, the update operation did not occur.PLease click ok and then click update again to save your changes."
Click OK
Second time message comes again with same description including VT Advantage .
click OK
The update does take effect though.
Conditions:
Applied ES26 on Call Manager 4.2.3 . Issue started after applying ES26
Workaround:
None
Hope this helps!
Rob
SELOMECIS Mon, 10/13/2008 - 23:55
I have found a solution on cisco site by research,i have to install ccm4.1 patch wich is devpack 4-1-3-sr5c.exe
