AP1121G - can't set to autonomous
We bought WLC-2106 and two AP-1121G.
AP-1121G was with autonomous software, so I downloaded software and
switched it to
lightweight mode, but it doesn't work.
I see in controller log :
*Oct 13 09:43:35.437: %LWAPP-6-DISC_RESPONSE_SENT: spam_lrad.c:1327
Discovery Response sent successfully to AP 00:21:55:74:af:82
*Oct 13 09:43:28.916: %DHCP-6-SCOPE_NOT_FOUND: dhcpd.c:167 Dropping
packet from (unable to match to a dhcp scope)
*Oct 13 09:43:28.915: %DHCP-6-SCOPE_NOT_FOUND: dhcpd.c:167 Dropping
Then AP reboots. management interface address.
dhcp.conf for AP:
option space ciscoap;
option ciscoap.vci code 43 = text;
option ciscoap.wcip code 60 = string;
host ap {
hardware ethernet 00:21:55:74:af:82;
option ciscoap.vci "VCI string" ;
option ciscoap.wcip C0:A8:16:12;
So I decided to return AP to autonomous mode.
I downloaded image, put it on ftp.
AP got it, rebooted, but seems it is still in lightweight mode- I see
the same messages on controller log and can't reach AP over http.
Could you tell me how can I
return AP to authonomous mode?
Is there any howto for adding AP to wlc2106?
thank you!
abhajha Mon, 03/24/2014 - 01:50
According to the log it’s not getting the DHCP server IP address . Please check if proper network DHCP server scope is defined and AP s connected to proper port.
There are many methods to convert the Lightweight to autonomous.
Please check the below link for conversion:-
