CCM 4.1 and CRA 3.5 help!
Oct 13th, 2008
  • Bronze, 100 points or more
Hi guys, I have a CCM and CRA (with aa script) integration on the same server cofigured for Auto-Attendant and a Cisco 3725 with a E1. The CTI RP is associated but when a user call from the PSTN, the AA takes like 15 seconds to answer. Does any one known what parameter should I modify to make the answer faster?
Thanks a lot forum
David
Overall Rating: 3 (1 ratings)
Brandon Buffin Mon, 10/13/2008 - 05:15
  • Purple, 4500 points or more
David,
Does this happen when you call the route point internally or just on external calls?
Brandon
david-lima Mon, 10/13/2008 - 05:33
Thanks for your mail Brandon, I have this problem only with external calls, If I dial the CTI RP internally, it answers inmediatelly.
Thanks again
David
Brandon Buffin Mon, 10/13/2008 - 05:46
How is the incoming call routed to CRA? A translation rule on the gateway? A translation pattern in CUCM?
Brandon
david-lima Mon, 10/13/2008 - 06:07
Hi Brandon, I have configured a connection plar on the voice-port of the E1 pointing to the CTI RP and it is registered correctly.
Thanks again
voice-port 1/0:15
connection plar 2888 -- CTI RP
David
Brandon Buffin Mon, 10/13/2008 - 06:12
Check the dial peer that 2888 uses to reach CUCM. Do you have more than 1 dial peer to route this call? Could it be trying the first dial peer, failing and using another dial peer to finally route the call?
Brandon
david-lima Mon, 10/13/2008 - 06:30
Thanks for your help my friend, I don't have any other dial peer or tranlation rule that has this pattern, they are different.
Thanks and best regards.
David
david-lima Mon, 10/13/2008 - 07:12
Thanks for your advices Brandon, I reload the CCM and it works fine now.
It was my last resort.
David
