DCOM through a FWSM
Oct 13th, 2008
I am trying to get Microsoft DCOM through a FWSM.
We use FWSM inside our network to protect our server subnets. One of the server is using RMC that is based on Microsoft DCOM.
My understanding is the DCOM uses port tcp/135 for the beginning of the conversation. It than switches to a port in the 1024-65535 range. It just seams like a waste of a firewall to open all ports in that range.
My understanding is that the DCERPC inspection is suppose to work on this protocol. This inspection is turned on in the global policy map and set for default.
service-policy global_policy global
policy-map global_policy
class inspection_default
inspect dcerpc
Is there anything special I need to get this going? Do I really need to open all tcp ports between 1024-65535?
Overall Rating: 4 (1 ratings)
Farrukh Haroon Sat, 10/18/2008 - 22:47
You should try your best to open a specific range only, this can be done by a registry hack in Windows:
http://msdn.microsoft.com/en-us/library/ms809327.aspx
Also ensure all communiction is in TCP and not UDP.
You can also use the 'established' command on the firewall instead of opening all ports falt out. However the established command is subject to some serious security riks (by virtue of bypassing the state checking).
Farrukh
cisco24x7 Sun, 10/19/2008 - 02:29
Use Checkpoint firewall. It can inspect DCOM
ports without having to open ports >1023, just
like Active or Passive FTP.
my 2c
