CISCO ASA denies certain websites
Oct 13th, 2008
hi,
I have a user with Vista who is unable to access certain websites, for example http://www.hsbc.co.uk. Most others on the network can access the website however it appears another user can't. Both users can access the site from home but not from the office using the same laptops. I am not sure which settings on the CISCO ASA I should change to resolve this issue.
I wondered if anyone had any ideas?
thanks
Gavin
hadbou Fri, 10/17/2008 - 08:44
  • Bronze, 100 points or more
You may have enabled URL filtering on ASA which will block the websites which you have configured to be blocked by the filter.Check if you have configured URL filtering and if so remove the URLS which you want to be accessed from the filtering configuration.
