cwwlse-1030-k9 problem
Oct 13th, 2008
dear all
i forgot the password of the cwwlse-1030-k9
and i try this below
0: CiscoBre
1: CiscoBreR
press 1
# erase config
when i press 1,it takes a long time but can not come into #
what can i do???
thanks a lot!!!
Overall Rating: 4 (1 ratings)
Rob Huffman Mon, 10/13/2008 - 07:08
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Jian,
Here is the whole process (check step # 4);
Recovering from the Loss of All Administrator Passwords
If you cannot log on to the system and perform administrative tasks, perform the following procedure.
Procedure
Step 1 If there is a monitor or keyboard connected to the WLSE, remove it.
Step 2 Connect a console terminal or PC running Hyper Terminal to the WLSE's console/serial port. Use the cable supplied with the WLSE and, if necessary, the DB-9-to-RJ-45 console adapter.
Note Use the serial port; do not use the video port.
For more information on the console/serial port, see the Installation and Configuration Guide for the CiscoWorks Wireless LAN Solution Engine:
•For the CiscoWorks 1130 WLSE, see
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cwparent/cw_1105/wlse/2_5/inst_gd/ig_inst.htm
•For the CiscoWorks 1130-19 WLSE, see
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cwparent/cw_1105/wlse/2_9/i_gd/ig_over.htm.
Step 3 Power the system off, then power it back on. Boot messages appear, and then following prompt appears:
0: CiscoBre
1: CiscoBreR
Step 4 Use the Up Arrow and Down Arrow keys to select 1 for CiscoBreR and press Enter. The following prompt appears:
bash-2.05a#
Step 5 Enter the following command. This erases the WLSE's configuration, returns the WLSE to factory defaults, and reloads the WLSE.
bash-2.05a# erase config
Step 6 After the WLSE starts up, a login prompt appears. Log in as setup, and use the setup program to configure the system. This allows you to add a password for the admin user.
http://www.cisco.com/en/US/docs/wireless/wlse/2.9/user/guide/CLIadmin.html#wp1075616
Hope this helps!
Rob
Trending Topics - Security & Network
