BAT CUCMBE 6.1.2 Importing Users Error
I am trying to add in users to a CUCMBE6.1.2 system using BAT. I have crested a user manually and exported the user records then editied and re-imported the additional user for testing
purposes.
I get 2 failures as below.
Insert Users
Begin Time : 10/13/2008 15:11:12
Query :
Insert Users in igiveup.csv
Failure Details :
users Error Code Error Description
JJ Could not insert new row - duplicate value in a UNIQUE INDEX column.
NLS Could not insert new row - duplicate value in a UNIQUE INDEX column.
Result Summary :
INSERT for 0 USERS passed.
INSERT for 2 USERS failed.
I wpoould expest JJ to fail as it was the template but user id NLS should go in fine. i have attached the csv file i am using and have ccreated the user template file.
This could be a simple error on my part i dont normally create users this way i use LDAP.
many thanks
jon
tim.giles Mon, 10/13/2008 - 09:19
  • Silver, 250 points or more
Hi Jon,
It's difficult to tell without looking but this error value usually means there is already an entry in the database with the same name - hence the reason it can't insert it again.
Have you checked to make sure there is not another user with the same details (apologies if you have!)?
Limarenko Mon, 10/13/2008 - 12:07
1. Sometime restart of the server helps.
2. it is possible if you have not correct cvs file .
