1510 Connection Issues
Oct 13th, 2008
I have a 1510 I just got back from a RMA and when we put it on the network it will connect and work then a couple hours later it will no longer show on the controller. Any ideas?
vlad.kabatov Mon, 10/13/2008 - 07:08
Is it mounted in the same place as it was before? Any obstructions?
nshoe18 Mon, 10/13/2008 - 07:17
We actually have tried it in the same place it was before as well as in computer room directly plugged into the network. Even plugged directly to the switch it will only function for a short time then drop.
dennischolmes Mon, 10/13/2008 - 10:46
  • Gold, 750 points or more
The unit you received back is probably not the same unit you sent in for RMA. You must add the new units mac address in the controllers mac filter to allow it to join the controller.
nshoe18 Mon, 10/13/2008 - 11:21
Sorry I should have put that...We have already got the MAC in a table. As I stated, the AP associates to the controller and after a period of time, it is no longer associated and does not come back. It is currently connected to the network using the Ethernet connection on the Access Point and it will not stay on the network with that connection either.
dennischolmes Mon, 10/13/2008 - 11:27
Clear the config on the AP and reset to factory defaults. Just because you got it from RMA doesn't mean it had not been out before. Then enable your LWAPP debugs and look for discovery traffic and see how the AP registers to the controller. Make sure the bridgegroup name matches as well.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
