Music-On-Hold
Oct 13th, 2008
Dear Folks,
I a have centralized Callmangers Solution.My remote sites are using local gateway for local calls using Analog PSTN interfaces.But Mobile and Long distance are using HQ PRI for making Calls.I am using unicast Moh and its working for local calls from remote site.But When I call from remote site to a long distance/mobile using HQ Pri ,I am getting tone on hold.
I have checked Region,MRG,MRGL and all are correct.
Could you please help me to solve this
allan.thomas Mon, 10/13/2008 - 14:23
  • Blue, 1500 points or more
The fact that you are receiving TOH instead MOH suggest that there is a configuration problem.
In this particular instance CUCM has failed to activate MoH and has defaulted to TOH.
Have you confirmed that calls established to these long distance or Mobiles numbers from within the same region as the HQ PRI can receive MoH and not from the remote office?
Rgds
Allan
Marwan ALshawi Mon, 12/08/2008 - 03:05
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
do u have enough dsp to do Xcoding!!!
Jaime Valencia Mon, 12/08/2008 - 09:24
  • Cisco Employee,
  • Hall of Fame,
    2011
have you tried enabling all the necessary codecs under the IPVMS service?
java
if this helps, please rate
