7921 Data Cables - Any benefits beyond charging the phone?
Oct 13th, 2008
I got some zCover phone covers to protect our 7921 phones and subsequently got the charging cables in to replace the very expensive charging stations (wish I woulda known about them earlier). Aside from the charging and manual fimware update/config, is there anything I'm missing as far as USB connection is concerned?
It seems like there would be an Outlook contact synch tool or some utilities floating around, but I haven't found any creative uses of the USB connection yet.
Is anyone doing anything with these out "in the wild"?
BTW - check out zCover if you need to use 7921s in a rugged environment. I have no affiliation to them other than as a customer.
