How to find the host based on IP address
Oct 13th, 2008
i have host connected to port on my swtiched network, please let me know on which and which post the host is connected
Host ip:10.1.89.50
1 step:
core720#p 10.1.89.50(host IP)
Sending 5, 100-byte ICMP Echos to 10.1.89.50, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
core720#
step 2:
core720#sh arp | in 89.50
Internet 10.1.89.50 0 0050.564b.65b6 ARPA Vlan90
step 3:
core720#sh mac-ad
core720#sh mac-address-table | in 0050.564b.00b6
* 90 0050.564b.65b6 dynamic Yes 0 Po10
core720#
please guide me from here to locate the on which switch the host(10.1.89.50) is connected
Jon Marshall Mon, 10/13/2008 - 08:41
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
You need to log onto the switch at the other end of po10 which is port-channel10.
1) sh etherchannel summary
will show you the individual ports within an etehrchannel. So lets assume po10 is made up of 4 ports gi3/1, 2, gi4/1, 2.
Pick one and then
2) sh cdp neigh gi3/1 det
this should give you the attached switch IP address - assuming it is a managed switch. Log onto that switch and repeat your step 3 ie.
sh mac-address-table address 0050.564b.00b6
Jon
Collin Clark Mon, 10/13/2008 - 08:43
  • Purple, 4500 points or more
You're on the right track. The switch has learned the MAC from Po10. Where does that go? An easy way to find out is 'show cdp nei inter [port channel member]'. That will show you the device. Then go to that device and show the MAC and keep going to the switch until you find the port.
http://www.packetpros.com/wiki/index.php/Cisco and go to How do I find a device in my network?
Hope that helps.
UCBNOCWAN Mon, 10/13/2008 - 09:12
Dear All,
still i am unable to locate plz find the output
core720#sh etherchannel su
1 Po1(SU) - Gi1/1(P) Gi1/2(P) Gi6/1(P) Gi6/2(P)
10 Po10(SU) - Gi1/21(P) Gi1/22(D)
11 Po11(SU) - Gi1/23(P) Gi1/24(D)
21 Po21(SU) - Gi8/1(P) Gi8/2(P)
50 Po50(SU) - Gi1/5(P) Gi1/6(P)
51 Po51(SU) - Gi1/7(P) Gi1/8(P)
52 Po52(SU) - Gi1/9(P) Gi1/10(P)
53 Po53(SU) - Gi1/11(P) Gi1/12(P)
core720#
core720#sh cdp ne gi1/21 de
Device ID: 3750-VC-2
Entry address(es):
IP address: 10.1.128.101
3750-VC-2#sh mac-address-table | in 0050.564b.65b6
90 0050.564b.65b6 DYNAMIC Po41
3750-VC-2#sh eth
3750-VC-2#sh etherchannel su
w - waiting to be aggregated
d - default port
Group Port-channel Protocol Ports
10 Po10(SU) - Gi1/0/49(P) Gi1/0/50(D)
11 Po11(SD) - Gi1/0/51(D) Gi1/0/52(D)
31 Po31(SU) LACP Gi1/0/1(P) Gi1/0/2(P) Gi1/0/3(P)
32 Po32(SU) LACP Gi1/0/5(P) Gi1/0/6(P) Gi1/0/7(P)
41 Po41(SU) LACP Gi1/0/41(P) Gi1/0/42(P) Gi1/0/43(P)
42 Po42(SU) LACP Gi1/0/33(P) Gi1/0/34(P) Gi1/0/35(P)
3750-VC-2#sh eth
BRA-R8-3750-VC-2#sh etherchannel su
Flags: D - down P - in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
u - unsuitable for bundling
d - default port
Number of channel-groups in use: 6
Number of aggregators: 6
3750-VC-2#sh cdp ne gi1/0/41 de
3750-VC-2#sh cdp ne gi1/0/42 de
3750-VC-2#sh cdp ne gi1/0/43 de
3750-VC-2#
Collin Clark Mon, 10/13/2008 - 09:21
If the switches are connected to non-Cisco or blade server switches (or even a server), you may hit this dead end and you have to physically trace one of the cables to see where it goes. Also double check that CDP is running on those ports.
UCBNOCWAN Mon, 10/13/2008 - 09:34
Hi ALl
CDP is enabled
GigabitEthernet1/0/41 is up, line protocol is up
Encapsulation ARPA
Sending CDP packets every 60 seconds
Holdtime is 180 seconds
GigabitEthernet1/0/42 is up, line protocol is up
Encapsulation ARPA
GigabitEthernet1/0/43 is up, line protocol is up
Encapsulation ARPA
plz advice
Jon Marshall Mon, 10/13/2008 - 09:37
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Yes but CDP would need to be advertised from the device at the other end as well and it doesn't appear to be.
It looks like you have VMWare servers at the end of this link.
Jon
Collin Clark Mon, 10/13/2008 - 09:40
OK, then you know what ports the uplink to the blade center switch is. From there you would have to do a physical trace (or buy Cisco blade switches).
