Identify unused ACLs and object groups
Oct 13th, 2008
Hello all,
Can anyone point me to a software product (preferably Cisco) that will analyze a PIX 6.3 firewall rule set and determine which ACLs are not in use and which object groups are not referenced by any ACLs? I know I can show access-list to see hit counts, but this firewall has thousands of rules.
Matt
bwilmoth Fri, 10/17/2008 - 08:04
  • Silver, 250 points or more
As far as I know there are some recommended practices allow you to summarize and simplify your ACE entries:
1)Use contiguous host addresses whenever possible. Aggegrate host statements in ACEs/object-groups into networks.
2)Use 'any' instead of networks, and use networks instead of hosts when possible.
3)Try to simplify object-groups. This can potentially save hundreds of ACEs when the ACLs are expanded.
4)Group together individual port statements into a range.
MATTHEW BECK Fri, 10/17/2008 - 13:07
Actually, that won't work with object groups like I have configured. When you do the show access-list command you get:
access-l YYY line 1 perm...
access-l YYY line 2 perm...
If I try to no out anything but the first line which includes the name of the object groups, I'm going to get an error. And I definitely don't want to delete the entire line because only 1 object in the group may be unused - the rest will be valid.
Thanks, and enjoy your weekend.
Matt
Farrukh Haroon Sat, 10/18/2008 - 22:41
  • Red, 2250 points or more
For the access-lists you could do it manually like the following.
Firsto do a:
show access-l | inc elements
Then compare it with:
show run access-group
Farrukh
cisco24x7 Sun, 10/19/2008 - 02:33
I've done this before and it was VERY painful.
Here is what i did:
1- Use a freeware tool call odumper/ofiller,
written by a Checkpoint engineer to dump
the rules and object into a Checkpoint
SmartCenter
2- In the Checkpoint security, I can use the
"right-click" functions to findout which
objects have NOT been used. This can be
relatively quickly
3- Use Cisco conversion tool to convert
Checkpoint rule back into Pix rules.
Step 1 and 2 worked quite well but step
3 was a big mess especially when you have
a large security policy.
my 2c.
