Cisco Network Assistant
Oct 13th, 2008
I installed and was able to use the Cisco Network Assistant. But when I setup the enable and vty passwords I get a dialog windows stating "Please enter your username and password for realm 'level_15_access' on xxx.xxx.xxx.xxx"
what username and password is it asking for? I know this is linked to setting up the enable and vty passwords but I can't figure out why.
Overall Rating: 4 (1 ratings)
Jon Marshall Mon, 10/13/2008 - 10:20
Cedric
If you haven't set up a local username then try
1) no username/password = enable secret password
2) username = cisco/password = enable secret password
Jon
jtphilies Wed, 10/22/2008 - 04:47
cedric, on the device your trying to access, you can,
config t
ip http server enable (to use the enable password to login
or
ip http server local (to use login of an account setup locally on the device)
then try to connect using CNA
svillardi Wed, 10/22/2008 - 07:44
I'm having the same issue. I am comparing the configs from 2 switches. One works with CNA, the other doesn't. Same model switch.
Goal: set up CNA using the same user/enable passwords as telnetting into the switch.
A few questions:
I looked at the vty settings for the working switch:
ip default-gateway 111.222.333.444
ip classless
ip http server
ip http secure-server
the non-working:
ip classless
ip http server
ip http authentication local
The working VTY:
ine con 0
stopbits 1
line vty 0 3
password 7 blahblahblah
login
length 0
line vty 4
login
length 0
line vty 5 14
login
transport input telnet
line vty 15
login
the NON working:
line con 0
line vty 0 4
password 7 blah
login
length 0
line vty 5 14
password 7 blah
login
line vty 15
password 7 moreblah
login
I just configured the line vty 15 and where it says password, I had to use "password 0 enablepswd". With a "sh run", it gave me the above.
Shouldn't it work?? The other one does!
svillardi Wed, 10/22/2008 - 08:55
A few questions:
ip classless
ip http server
the non-working:
ip classless
ip http server
The working VTY:
ine con 0
stopbits 1
line vty 0 3
login
length 0
line vty 4
login
length 0
line vty 5 14
login
line vty 15
login
the NON working:
line con 0
line vty 0 4
password 7 blah
login
length 0
line vty 5 14
password 7 blah
login
line vty 15
password 7 moreblah
login
MUHAMMAD SHAHEEN Wed, 10/22/2008 - 07:40
Use the username "en" and password whatever you have specified.
that should work
Hope this Helps
Shaheen
Pravin Phadte Wed, 10/22/2008 - 10:55
hi,
Try removing the command. "ip http authentication local"
the non-working:
ip classless
ip http server
Also try to just provide the enable password without any username.
Hope this helps,
Pravin
svillardi Wed, 10/22/2008 - 11:27
I think that's it! the ip http authentication local was the problem.
CSCO12577916 Wed, 11/12/2014 - 01:08
Resolve it by adding the below command ::::
(conf)# ip http authentication local
