10-13-2008 10:21 AM - edited 03-03-2019 11:54 PM
I am having a heck of a time figuring out what to do to MUX 2-t1's together between a 2600 and a 6500 with an ATM backbone. From what I can tell, the 6500 can't do the multilink but the 2600's can??? This is ALL I have configured so far on the 2600. I have read through the cisco docs and I am just more confused...how do I know if I am doing frf.5, frf.8, or frf.16? What about the 6500 side? Can someone help? Do I need an interface mrf or interface multilink? What version would I need?
interface Serial0/0
description T1 Frame Relay
bandwidth 1536
no ip address
encapsulation frame-relay IETF
no ip mroute-cache
load-interval 30
no fair-queue
service-module t1 timeslots 1-24
frame-relay lmi-type ansi
interface Serial0/0.18 point-to-point
description to ATM6/0/0.18
bandwidth 1536
ip address 10.10.10.6 255.255.255.252
ip load-sharing per-packet
ip ospf mtu-ignore
frame-relay interface-dlci 18
interface Serial0/0.29 point-to-point
description to ATM9/0/0.29
bandwidth 1536
ip address 10.10.10.38 255.255.255.252
ip ospf cost 1000
ip ospf mtu-ignore
frame-relay interface-dlci 29 IETF
interface Serial0/1
bandwidth 1536
no ip address
no ip mroute-cache
load-interval 30
no fair-queue
interface Serial0/1.16 point-to-point
description to ATM6/0/0.77
bandwidth 1536
ip address 10.10.10.242 255.255.255.252
ip ospf mtu-ignore
frame-relay interface-dlci 16
interface Serial0/1.23 point-to-point
description to ATM6/0/0.23
bandwidth 1536
ip ospf cost 1000
ip ospf mtu-ignore
frame-relay interface-dlci 23
10-13-2008 11:00 AM
Hello Aaron,
I think here you can:
just get two or four parallel L3 links that use FRF.8 service interworking between the c2600 and the C6500.
You could use multilink FR FRF.16 but only if the device to where your serial interfaces are connected support it. In your scenario I would keep the serial used in stand-alone
On the ATM side:
you will see two to four ATM PVCs that are mapped to two to four FR DLCI by service interworking that is done by WAN provider
If you have two FR links and two ATM links you can build a full mesh:
first dlci serial1 to first atm subif atm 6/0/0
second dlci serial1 to first atm subif atm 9/0/0
first dlci serial2 to second atm subif atm 6/0/0
second dlci serial1 to second atm subif atm 6/0/1
In this way if at least a FR link is up and an ATM is up you have connectivity
Config will be likely IPv4 over ATM using aal5snap
Interface ATM6/0/0
no ip address
no ip directed-broadcast
no atm enable-ilmi-trap
no atm ilmi-keepalive
interface ATM6/0/0.77 point-to-point
mtu 1536
bandwidth 768
ip address 10.10.10.241 255.255.255.252
pvc 10/100
abr 768 768
oam-pvc manage
encapsulation aal5snap
int atm 6/0/1
no ip address
int atm 6/0/1.29
mtu 1536
bandwidth 768
pvc 10/100
abr 768 768
oam-pvc manage
Note:
use different ip subnets on the four links
OSPF will manage 1 to 4 parallel links by default
very important: atm subifs must be point-to-point too or ospf network type will not match.
Hope to help
Giuseppe
10-13-2008 11:14 AM
how do i know if I am doing frf.8 or frf.16? Should int atm6/0/1.29 have the same ip as atm6/0/0.77...I think that was my typo on the original posting...atm6/0/1.29 should be 10.10.10.246...the real addresses are on different subnets. Isn't there something I would have to do on the LS1010 after I do this on the 6500?
10-13-2008 11:28 AM
if using FRF.16 on the ATM side you have only one interface and only one L3 interface under MFR interface on serial side
Ask you provider or you are doing a lab ?
I think that likely you need to configure the serial interfaces as stand alone links
Setting the same ip address on different subifs is NOT a way to perform FRF.16 multilink FR and not a way to do FRF.8
if you are in a lab anything is under your control but also I think you can do FRF.8 interworking on distinct links on LS1010 not sure you can also do FRF.16 at the same time (I suppose you cannot but you can try)
I would suggest you to follow previuos post 's suggestions
to study FRF.16 see the following doc
Hope to help
Giuseppe
