ACSv4.2
Answered Question
Oct 13th, 2008
Has anyone seen this before? Interface configuration options, under select, There are only two options User_data_configurations and Advanced Options - I have re-image this box twice and same results. Thank you... See image attached
Correct Answer by Jagdeep Gambhir about 8 years 8 months ago
Rest option will show up once you add any aaa-client.
Like if you add any switch using radius ietf, then radius will show up in interface configuration.
~JG
Do rate helpful posts
Overall Rating: 5 (1 ratings)
Correct Answer
Jagdeep Gambhir Mon, 10/13/2008 - 13:37
  • Red, 2250 points or more
~JG
