how do i activate nokia intellisync license
Answered Question
Oct 13th, 2008
all , i have bought the nokia icc license . from my e71 , i was prompt for a 12 digit license code which i cant find on the nokia license purchase confirmation letter.the letter hav a 10 and 11 digit number but dont see a 12 digit code.
i am using icc v1.1.2 with ccm7970
regards,
Correct Answer by pasimahone about 8 years 9 months ago
Just add 0 to begin of the code.
(before 8 ;) )
Cisco printing service has dropped leading zero for some reason
-Pasi-
Overall Rating: 5 (1 ratings)
Correct Answer
pasimahone Tue, 10/14/2008 - 03:04
  • Bronze, 100 points or more
(before 8 ;) )
-Pasi-
shingphing_2 Tue, 10/14/2008 - 06:27
pasi,
thks . nokia hav replied as what you have mentioned. One question tho , i have successfully registered e71 to ccm6 .but cant seem to get the mwi on unity work on the phone. any advise ??
Regards,sp
pasimahone Tue, 10/14/2008 - 07:44
First make sure that SCCP VoIP profile is preferred profile(to check this goto menu-> Communic.-> Internet tel.)
Then add Internet call mailbox number.
goto menu-> Communic.-> Call mailbox, or long press key 1 in idle screen.
Then reboot the phone and wait until device registers, now you should get notification (sms look-a-like)
-Pasi-
shingphing_2 Tue, 10/14/2008 - 07:57
pasi,
is internet call mailbox number the voicemail pilot number or the user extension number?
i hve configured as the pilot number and it did not work.
regards,sp
pasimahone Tue, 10/14/2008 - 09:56
Voicemail pilot number, the same number you make a call to listen voicemails.
-Pasi-
shingphing_2 Tue, 10/14/2008 - 10:12
Pasi
Thanks for your prompt response.
I hve in fact configured the pilot number , but did not reset the phone .will test it out again .
Regards,sp
