Problem to add any parameters
Answered Question
Oct 13th, 2008
  • " /> Participante em Destaque,
    Prêmio"Escolha dos membros": novembro de 2014
Hi Guys,
I am trying configure any parameter: region, location, user, etc.. and I receive the message "error on page". This version is CCM 4.2.1. What could is occuring? any ideia?
Thank You,
Wilson
Correct Answer by Jaime Valencia about 8 years 8 months ago
goga means don't do it from a remote computer, either do a RDP, VNC or directly on the console from the server.
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
gogasca Mon, 10/13/2008 - 14:58
  • Green, 3000 points or more
Do it directly from the server and make sure you authenticate twice if you get java auth window
wilsonsant Mon, 10/13/2008 - 15:01
Hi Gogasca,
I am sorry, but I don't understand that you speak? Could be more clear?
Thank You,
Wilson
Correct Answer
Jaime Valencia Tue, 10/14/2008 - 07:32
  • Cisco Employee,
  • Hall of Fame,
    2011
java
