CVP As Gateway
Oct 13th, 2008
I am not able to add CVP in cisco callmanger as voice gateway. I added the CVP as H.232 gateway but still the status is unknow.
Please help me out how to solve this problem. I have restart CVP and CCM but still i m getting status unknow.
I have made the route pattern xxxxx which points towards the CVP but no result.
Overall Rating: 3 (1 ratings)
Md. Mijanur Rahman Mon, 10/13/2008 - 19:34
  • Silver, 250 points or more
It will remain unknown, don't worry.
But you can specify your route patterns with this gateway and it will work fine. Have a test by setting a route pattern with 'Gateway/Route List' pointing to CVP, issue 'ss'/'sss' command at 'VB Admin', you will see call are coming there.
Please rate if helpful.
wasiimcisco Tue, 10/14/2008 - 01:59
Thanks for the reply, but still not working. When I dialed 33333 i m getting fast busy.
Though Agent phone, and gateway are in the same CSS.
When I did the ss and sss in VB admin no calls in progress, no IVR Ports active.
Md. Mijanur Rahman Tue, 10/14/2008 - 02:33
Hi Wasiim,
There are many reasons your IVR ports are not active. Look for this issue later, first look for whether the calls are counting by VB. Can you see any number count as 'Total Calls:' after issuing the command 'ss'? If it's still zero, then you can't reach the VB. If you think you can't reach it for permission related complexities, roll back all devices at CSS, then look for the 'Total Calls:' again. Did you configured the route pattern correctly with CVP as gateway? Do you have any firewall between CVP and CCM?
After that, your IVR ports might not be active if your VRU PIM is not active or if the link between VB and AS is down or ICM subsystem is not active. You will hear 'critical error message' if ICM returns any error.
wasiimcisco Tue, 10/14/2008 - 06:17
Thanks for the reply, I think problem has resolved. I think I was using wrong CSS.
The counter in VB is increasing whenever i dial the number. I am getting this message, We are currently face the difficulties with the sites.
VRU PIM is active. only problem is now that is strange I am not able to add the CVP server in Routing Group.
In Callmanger I am not able to add CVP in routing group.
Route pattern is xxxxx and points towards the CVP Ip address.
Pleaes tell me why it is so, I had screen shot of live enviroment Callmanger where i can that CVP is added as gateway in Routing Group of Callmanger.
Md. Mijanur Rahman Tue, 10/14/2008 - 07:04
Hi Wasiim,
First, that 'critical error message' don't relate with the route group you are trying to configure at CCM. How many CVP with you are playing with? You don't need to configure the route group if you have a single CVP box. Can you get the 'ICM Subsystem' is up and running from Application Administration page?
Second, there should be a specific error message at voice browser window, you will find it at 'CVP Monitor' option.
wasiimcisco,
Why don't you tell us what you are trying to do here?
It appears you are trying to get a CVP application to run from a call from an IP phone. Is that correct?
Do you have CVP working on calls to the gateway from the PSTN or an FXS port?
How much CVP background do you have?
Geoff
wasiimcisco Tue, 10/14/2008 - 12:12
I want to configure when user dial 33333 they heard a welcome prompt and their call transfer to ADS.
I have confiugre most of the configuration in terms of CVP and ICM PG etc. All services are up and running and now only scripting left, please help me out how to creat script in ICM.
wasiimcisco Tue, 10/14/2008 - 12:10
I have only CVP server. Now at least I am able to reach ADS after dialing a DN configured in ICM Dialed Number script. After 20 seconds I am getting this Message that WE ARE HAVING TECHNICAL PROBLEM WITH SITE.
Now please let me know how to configure ICM Script that user when dial 33333 it hears the prompt and in the mean while agents
receive the call.
I dont have any GW/GK. I am using CVP as voice gateway.
All the ICM services are up and running and ICM subsystem is also up and running.
Now please guide me how to creat script, I m not familar with scripting. Please help me out.
Md. Mijanur Rahman Tue, 10/14/2008 - 19:54
While this error prompt is generating, it's also showing error at CVP monitor and/or at ' Router router' at your ICM router, you can guide yourself to resolve those.
Here you will find the installation and configuration guide for your guidance:
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/ipcc_enterprise/ipccenterprise7_0/installation/guide/ipce70ic.pdf
You will need a GK to register your CCM and CVP, otherwise calls at return path from router can't reach it's label.
Here is the ICM scripting guide with some examples at the end:
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/ipcc_enterprise/ipccenterprise7_0/user/guide/ipce70sg.pdf
wasiimcisco writes:
"I want to configure when user dial 33333 they heard a welcome prompt and their call transfer to ADS."
What sort of user? A user with an IP phone? I guess so, but please confirm. Do you want a user on an IP phone to be able to call 33333? It sounds like it.
What is ADS?
You typically need a voice gateway to run the VXML. You need either a gatekeeper for H.323, or you need to use SIP. You say that you do NOT have a voice gateway! An unusual set up.
In the early versions of ISN/CVP you could get the VXML to run on the Voice Brower - in fact, when I first tried to set up CVP three or four years ago, that's where my VXML script was running, much to my dismay. That's why it was called a Voice Browser.
It's possible that this functionality still exists.
But this is not how CVP should be used. You would not be taking advantage of queuing at the edge of the network.
If all you require is for IP phones to run IVR scripts, wouldn't the IPIVR be a better choice?
Geoff
wasiimcisco Wed, 10/15/2008 - 05:42
This is my lab setup. That is why i dont have any voice gateway.
I want user with IP phone when calls 33333 their call transfer to user who is login with Agent desktop software.
and when agent will be in no ready state, the user get the Waiting prompt.
So far i have configure the ICM with CCMPG, VRUPG, skill group, agent desktop setting profile, dailed number (33333).
Now I wana have help in creating a basic Queue script. Any screen shots will be highly appreicated.
Riccardo Bua Wed, 10/15/2008 - 06:16
  • Cisco Employee,
You would need a Voice GW for all this like the others are saying or any sort of Call Server to process the VXML requests.
Riccardo
wasiimcisco Wed, 10/15/2008 - 08:05
My friend caller are not coming from PSTN side. This is my lab setup. All the agents are register with on Call manager. THis is some sort of Agent to agent call.
Edward Umansky Wed, 10/15/2008 - 15:05
A typical CVP install requires two types of gateways (which can be colocated on a single physical router): An ingress gateway and a vxml gateway. You are correct that you do not need an ingress gateway since this is a lab and all calls are originating from an IP Phone, but you still need a VXML gateway. This gateway acts as a voice browser and is used to terminate the call while it is receiving IVR or queue treatment. Lab or no, if you need to provide IVR treatment to the caller you must have a vxml gateway. If you are using H323, you will also need a gatekeeper, CVP will not function without it.
wasiimcisco Mon, 10/20/2008 - 13:27
I have configured the Voice GW and GK. see the attachement for configuration. Now still when i dial 33333 i m getting busy tone.
I also want to know, my gateway is added in CCM with route pattern 33333 but statu is unknow. I also have CVP as voice gateway with pattern xxxxx. Shall i remove CVP from CM bcz now i have gw/gk.
gatekeeper#sh gatekeeper endpoints
GATEKEEPER ENDPOINT REGISTRATION
CallSignalAddr Port RASSignalAddr Port Zone Name Type Flags
172.28.49.244 1720 172.28.49.244 55952 gatekeeper VOIP-GW
H323-ID: vg
Voice Capacity Max.= Avail.= Current.= 0
Total number of active registrations = 1
gatekeeper#sh gatekeeper zone pre
gatekeeper#sh gatekeeper zone prefix
ZONE PREFIX TABLE
GK-NAME E164-PREFIX
gatekeeper 33333*
voice gateway
vg#
*May 10 05:07:12.768: h323chan_chn_process_read_socket: fd=0 of type LISTENING has data
*May 10 05:07:12.768: Changing to new event: ACCEPT
h323chan_chn_accept: fd=0
*May 10 05:07:12.768: h323chan_gw_accept: TCP connection accepted from 172.28.49.231:57924 on fd=3
*May 10 05:07:12.768: h323chan_chn_accept: Local(0x0) accepts TCP conn from 172.28.49.231(0xAC1C31E7) port (57924); fd=3changing from LISTENING state to ACCEPTED state
*May 10 05:07:12.768: h323chan_chn_process_read_socket: fd=3 of type ACCEPTED has data
Hex representation of the SETUP TPKT received: 080200050504038090A26C070081353530383870068033333333337E00680520B0060008914A0002020200883BB40400350035003000380038020001020066666080EB2B74EDBCE11D05005D01AC1C5C4800450C0700AC1C31E706B8110080EB2B74EDBCE11D05005D01AC1C5C48010001000AA001000F0140B50000120880C4000400010100
h225ParseData: Q.931 SETUP received on fd=3
*May 10 05:07:12.772: h323chan_chn_process_read_socket: fd=2 of type CONNECTED has data
*May 10 05:07:12.772: compose_TunnelledSignallingMessage_ciscoNo tunnelled content.
Hex representation of the RELEASE COMPLETE TPKT to send.: 080280055A080280837E0022052580060008914A00041100110080EB2B74EDBCE11D05005D01AC1C5C4810800100
h225TerminateRequest: Q.931 RELEASE COMPLETE sent from fd=3. Call state changed to [Null].
*May 10 05:07:12.776: h323chan_chn_process_read_socket: fd=2 of type CONNECTED has data
*May 10 05:07:12.776: h323chan_chn_process_read_socket: fd=3 of type ACCEPTED has data
*May 10 05:07:12.776: h323chan_recvdata: Connection lost fd=3h323chan_chn_close: Calls[1] Exist on socketfd=3 Owner[2]
*May 10 05:07:12.776: h323chan_close: TCP connection from fd=3 closed.
Md. Mijanur Rahman Mon, 10/20/2008 - 20:01
1. You need to register your VG, CVP and CCM (through trunk) with the GK, i can see you have only registered your VG.
2. You will need to add a zone prefix against your phone DN so that CVP can find your phones.
3. Keep the CVP as H.323 gateway in the CCM. It will need while you are trying test dialing '33333' from your phones.
Hope this help.
wasiimcisco Tue, 10/21/2008 - 01:55
MY CVP IP address 172.28.49.247
ICM IP address 172.28.49.240
CCM IP Address 172.28.49.231
Voice Gateway Ip address 172.28.49.244
Gatekeeper IP Address 172.28.49.230
IPT Agent extensions 550xx
Dialed Numbers: 33333
Please see updated gatekeeper configuration;
gatekeeper
zone local gatekeeper warid.com 172.28.49.230
zone prefix gatekeeper 33333* gw-priority 10 vg
zone prefix gatekeeper 550.. gw-priority 10 CRA-TEST
gw-type-prefix 3#* default-technology gw ipaddr 172.28.49.244 1720
gateway added in CCM against RP 33333.
CVP add as gateway in CCCM against RP xxxxx
gatekeeper added as intercluster trunk, against technology prefix 3#.
Zone name is gatekeeper.
But still getting the busy tone, What about my script, can u check and let me know is it right or wrong and what my call is not getting through.
Md. Mijanur Rahman Tue, 10/21/2008 - 03:11
Why did you set the zone prefix: 'zone prefix gatekeeper 33333* gw-priority 10 vg' ?
It will redirect you call to the H.323 voice gateway, then? How you will treat it?
What is the device 'CRA-TEST'?
At the very first before you move for dialing your DN, make sure your VGW, CVP and CCM are registered with your GK.
You will get the procedure to register your CVP with GK at 'Configuration and Administration Guide' of CVP.
Also create a GK controlled trunk at CCM, put the parameters correctly there, reset the trunk after completed. Then issue 'show gatekeeper end' from GK and confirm both of these three are registered.
Then select the CVP or CCM Trunk at RP while you are dialing from agent phone.
If you still get reorder tone or CVP critical error message, paste the error seen at ICM Router.
Hope this will help.
wasiimcisco Tue, 10/21/2008 - 14:35
I have modified the configuration, now see CVP, CCM, VG are successfully registered with GK.
172.28.49.231 52482 172.28.49.231 51637 gatekeeper VOIP-GW
H323-ID: gatekeeper_1
172.28.49.244 1720 172.28.49.244 50070 gatekeeper VOIP-GW
H323-ID: vg
172.28.49.247 1720 172.28.49.247 1719 gatekeeper VOIP-GW
H323-ID: 172.28.49.247
Total number of active registrations = 3
CVP, VG, GK are added in CCM. Intercluster trunk also configured. I made a route pattern 33333 points towards the Trunk. Only one route pattern in CCM. I have restart gw,gk,ccm,cvp.
Gatekeeper configuration:
gatekeeper
zone prefix gatekeeper 33333* gw-priority 10 172.28.49.247 (CVP IP ADDRESS)
zone prefix gatekeeper 550.. gw-priority 10 172.28.49.231 (CALLMANGER IP ADDRESS)
no shutdown
Gateway configuration:
h323-gateway voip interface
h323-gateway voip id gatekeeper ipaddr 172.28.49.230 1719
h323-gateway voip h323-id vg
h323-gateway voip tech-prefix 2#
When i am check CVP with ss and sss in VB Admin.
I am not getting any call.
ICM router is also not showing anything whenever i dial 33333 from IP phone. I m still getting fast busy. and also getting THERE IS NO BANDWIDTH AVAILABLE message on phone.
I have made the media Termination point and applied it on Device Pool. But still the problem is same.
What to do now.
Md. Mijanur Rahman Tue, 10/21/2008 - 19:58
A small correction:
--zone prefix gatekeeper 33333* gw-priority 10 172.28.49.247 (CVP H323 ID)
--zone prefix gatekeeper 550.. gw-priority 10 gatekeeper_1 (CALLMANGER H323 TRUNK)
you will need a voip dial-peer at VGW with 'destination pattern 33...' and 'session target ras', it will work.
You can have a small workaround, reconfigure your RP pointing to CVP.
wasiimcisco Wed, 10/22/2008 - 01:26
Still the situation is same. I have change the RP 33333 towards CVP.
Reconfigure the Trunk with GK. Restart the CCM.
See the latest configuration of VG
interface GigabitEthernet0/0
ip address 172.28.49.244 255.255.255.0
duplex auto
speed auto
negotiation auto
dial-peer voice 33333 voip
description **** PrePaid Calls *****
destination-pattern 33333
voice-class h323 1
session target ras
tech-prefix 2#
dtmf-relay rtp-nte h245-signal h245-alphanumeric
codec g711ulaw
no vad
Gatekeeper configurtaion.
gatekeeper
zone prefix gatekeeper 550.. gw-priority 10 gatekeeper_1 172.28.49.231
no shutdown
But CVP still not able to receive the call, ICM router is not showing any error.
I have restarted all machines but no luck.
The basic steps are as follows:
1. The route point (or you can do this through a DNP) makes a post route request on the CUCM RC.
2. The dialed number is assigned to a call type.
3. The call type maps 1-1 to a routing script.
4. The first node is a "Send To VRU" node.
5. This returns a label configured on the NVRU for the CUCM RC (not the label on the CVP RC - a different label). For example, 1999999999. The Call Router pauses the script.
6. The correlation ID is appended and there needs to be a way for CUCM to find a CVP Call Server (in your case, via the GK).
7. The Call Server sends a request instruction up through the CVP PG and the Call Router resumes the script it paused. At the next "Queue" or "Run Ext Script" node, the Router does an implicit "Send To VRU". This returns the label on the CVP RC - say 8111111111.
8. The gatekeeper needs to have a way of sending this call to start the VRU leg on the gateway. Now the call is queued on the gateway.
9. Normal CVP stuff now - the agent becomes available and returns the device target, and the gatekeeper resolves this to be handled by CUCM etc.
Geoff
wasiimcisco Thu, 10/23/2008 - 13:54
In dialed Number Tab, I have the following Configuration.
dialed number : CCMPG.RC.33333 and default label is 2000
dialed number : VRUPG.RC.33333 and default label is 3000
dialed Mapped Number: Call type= Pre-Paid.
Answer: dialed number : CCMPG.RC.33333 and default label is 2000
zone prefix gatekeeper 200* gw-priority 10 172.28.49.247 (CVP IP address)
Answer: In my case, The call is orignated from IP phone regester in CCM, means calls again comes back to CCM. So I am adding
another zone prefix in GK pointing towards Callmanger.
zone prefix gatekeeper 300.. gw-priority 10 172.28.49.231
But still the problem is same, still getting busy tone,
Your answer was not relevant.
What are the labels you have on the two routing clients for the Network VRU?
Geoff
usman.amjad Fri, 10/24/2008 - 06:36
I have The following Configuration in Network
VRU Explorer.
For Type 5
CCMPG.RC label is 20000
VRUPG.RC label is 3000
I have another network VRU for Type 7
VRUPG.RC label is 3002
This is all I have in Network PG Explorer Window
