Etherchannel to HP Server from 6500 - Multiple Port-Channels?
meballard
I created a port-channel on a HP server using LACP to a Cisco switch, and it seems to create two port channels, one of which the server uses, one of which it doesn't. This is the result of the show etherchannel 1 sum:
Group Port-channel Protocol Ports
1 Po1(SU) LACP Gi3/3(P) Gi4/3(P)
1 Po1A(SU) LACP Gi3/31(P) Gi3/32(P) Gi3/33(P)
Gi3/34(P)
The server is configured for 802.3ad, and it shows the two ports in Po1 as not being active, and the other four as being active. What would cause the 6500 to create the second port channel like that?
I used this for the configuration on the Cisco switch for all 4 ports:
channel-protocol lacp
channel-group 1 mode active
If it helps, I attached the show etherchannel 1 det.
Calin C.
Level 5
Level 5
Hi!
Can we see an output of
"show run int gi3/3"
"show run int gi3/31"
"show run int po1"
Thanks!
Calin
Here it is:
gahmnb01-rt01#sh run int gi 3/3
Building configuration...
Current configuration : 248 bytes
interface GigabitEthernet3/3
description GISPW3BK01
switchport
switchport access vlan 233
switchport mode access
no cdp enable
spanning-tree portfast
spanning-tree bpdufilter enable
end
gahmnb01-rt01#sh run int gi 3/31
Current configuration : 249 bytes
interface GigabitEthernet3/31
switchport
no cdp enable
end
gahmnb01-rt01#sh run int po1
Current configuration : 95 bytes
interface Port-channel1
switchport
end
steve_steele
My guess on this is that LACP has negotiated 2 links because you have 6 configured on the 6500 and the HP server only supports up to 4 links in a single channel.
Check the driver specifications for the NIC's
You could try shutting down one of the currently active ports to check if one of the other ports turns active, which would suggest a 4 port maximum.
Hope this helps
Steve
When I shut down one of the active NICs, either on the server or on the core, it does this:
1 Po1(SU) LACP Gi3/3(P) Gi3/32(D) Gi4/3(P)
1 Po1A(SU) LACP Gi3/31(P) Gi3/33(P) Gi3/34(P)
I saw the same thing happen on another HP server that I created a port channel with only 3 NICs (with it creating two port channels, where the one with 2 was active, and the one with 1 wasn't).
