Distributing bandwidth
Oct 13th, 2008
I have 3 mb down and 1mg up internet connection I want to distribute the bandwith between 2 networks first 1 mb 512 k up and the second 2mb down 512 k up
is there a cisco hardware product to do so ??
satish_zanjurne Mon, 10/13/2008 - 21:08
  • Silver, 250 points or more
1.Is this a DSL link, as it is supporting asymmetric speed ??
2.I will recommed you Ciso 1700 or 1800 series routers with HWIC on it to support 3 mb
HTH...rate if helpful..
faleb1977 Tue, 10/14/2008 - 01:56
well its not DSL its a 2 way (up/down)satellite link using an idirect receiver/transmiter!
Joseph W. Doherty Tue, 10/14/2008 - 05:48
Cisco routers that support QoS can effectively divide outbound bandwidth, but doing the same for inbound bandwidth isn't usually practical. The best for the latter is usage of a bandwidth management product. Don't believe Cisco has any, but there are a couple other vendors that do.
