Jon Marshall Mon, 10/13/2008 - 23:33
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
If you mean find the IP address from the mac-address by interrogating your router then the answer is no.
Mac-addresses are only local to the LAN so if the device is 4 or 5 hops away it the packet on your router will only have the mac-address of the last hop.
Jon
csc010854800 Tue, 10/14/2008 - 00:02
HOST 1----R1--R2--R3-----R4-----R5---HOST 2
please clarify , if i have a mac-address of HOST 2 , then which Router will be the last hop for HOST 1 ...... and the command for that ???
Mo'ath Al Rawashdeh Tue, 10/14/2008 - 00:55
  • Bronze, 100 points or more
For your scenario above, you can know the IP address of Host2 from the MAC by issuing the "R5# show arp" command on router 5 only, as this router is the default gateway for Host2.
Cheers mate.
