CCME - Remote teleworker g729r8 silence
Oct 14th, 2008
Hi all.
Ive got a CCME 2811 at head office and an 800 series router at a remote site, with a VPN tunnel.
Calls work between both sites really well using the default codec, but at times bandwidth is an issue.
When I try to make the remote phone use g729r8, then place a call, there is no sound either way, so this must be a transcoding problem.
Any ideas what i should look at first?
Huw
