ASA Question-Help needed
Oct 14th, 2008
I have configured and integrated an ASA to my network.
Inside----ASA----ROUTER-----Internet
I have 3 servers in my inside network,one of them is a proxy server which all other users use. The 3 servers have both public and private addresses.I have done two layers of nat,one on the ASA and the other on the router.
My inside users cannot ping the inside interface of the router neither can they browse.
I have attached the configs on the ASA and router.
Can someone please take a look at it and let me know where I got it wrong.
JORGE RODRIGUEZ Thu, 10/16/2008 - 12:13
  • Green, 3000 points or more
Can you post a more complete asa sanatized config to get a better picture and see the nonat acls. You said that your inside users cannot get to the inside interface of the router facing asa outside interface and browse, if this is so you simply need a nat statement.
e.i
your asa already have this statement
global (outside) 1 interface
do you have these ?
nat (inside) 1 0 0
or
nat (inside ) 1
Jorge
sameoj1881 Fri, 10/17/2008 - 01:22
ASA Configs
static(inside,outside) x.x.103.5 x.x.101.5 netmask 255.255.255.255
static(inside,outside) x.x.103.250 x.x.101.250 netmask 255.255.255.255
static(inside,outside) x.x.103.2 x.x.101.2 netmask 255.255.255.255
access-list 100 extended permit icmp any any
access-list 100 extended permit tcp any host x.x.103.5 eq 80
access-list 100 extended permit tcp any host x.x.103.250 eq 80
access-list 100 extended permit tcp any host x.x.103.2 eq 25
int e0/1
access-group 100 in interface outside
access-list NO-NAT extended permit ip x.x.101.0 255.255.255.0 any
nat(inside) 1 access-list NO-NAT
global(outside) 1 interface
route outside 0.0.0.0 0.0.0.0. x.x.103.7
Router Configs
access-list 10 permit x.x.103.0 0.0.0.255
ip nat inside source list 10 interface fa0/0 overlaod
ip nat inside source static tcp x.x.103.5 80 x.x.39.155 80
ip nat inside source static tcp x.x.103.250 80 x.x.39.156 80
ip nat inside source static tcp x.x.103.2 25 x.x.39.73 25
int fa0/0
ip nat outside
int fa0/1
ip nat inside
Fernando_Meza Thu, 10/16/2008 - 13:49
  • Gold, 750 points or more
Make sure you are not filtering out that traffic on the router by the use of access control lists ..?
I hope it helps .. please rate helpful posts
marchanamendon Tue, 10/21/2008 - 01:25
You can make the configuration as simple,by controlling all the nat operation at the firewall and allow only routing in the router.It will make as simple the configuration.
Archana.
