Which is better lease line or VPN??
Oct 14th, 2008
Hi..I need to connect 10 sites with no web portal,public users...which is better between lease line or VPN ..is there a need of firewall?...Does VPN also covers the L4-L7 securities ??..should I go for lease line or VPN ??
When I go for VPN, still there is a need of Firewalls to provide the L4-L7 securities if Web servers are there ...??
Please suggest me ..
-Sanjeev
Overall Rating: 4 (1 ratings)
Sanjev,
In my opionion - there is no right ro wrong answer, you need to consider:-
1) Cost
2) Number of devices to manage
3) Cost
VPN's are cheap - becuase internet circuits are cheap, but you have contention ratios, reliability issues and banwdith contrants.
Leased lines are not cheap - but you do get 100% of the bandwdith you buy.
With a leased line - you do not need a firewall, with the VPN you do.
The VPN can cover L4-L7 security.
If you go for a VPN yes you should use a firewall.
HTH>
ror.sanjeev Wed, 10/15/2008 - 01:57
Hi..Thank you very much for the response..If I want to establish site-to-site VPN over Public Internet with IPSec then dedicated Internet bandwidth i will use ...
If VPN can cover L4-L7 security then still there is a need of firewalls????.please tell me how VPN covers L4-L7 security..
can u please suggest/explain why there is no need of firwalls in case of lease line..?
-Sanjeev
