Problem in VRRP configuration between two VPN Concentrator
Oct 14th, 2008
  • Silver, 250 points or more
I've a problem as specified in Title.
It seems that the configuration is correct, but when I shutdown the master I can't ping to the virtual address..the standby is on and I can manage it....but the virtual address is not responding.
Any ideas?
Thank you.
Best regards.
Massimiliano.
Overall Rating: 3 (1 ratings)
ajagadee Tue, 10/14/2008 - 17:14
  • Cisco Employee,
I think this is expected behavior.
Note: VRRP enables redundancy for tunnel connections only. Therefore, if a VRRP failover occurs, the backup only listens to tunnel protocols and traffic. Pinging the VPN Concentrator does not work. Participating VPN Concentrators must have identical configurations. The virtual addresses configured for VRRP must match those configured on the interface addresses of the Master.
Please refer the below URL for details:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2284/products_tech_note09186a0080094490.shtml
Arul
** Please rate all helpful posts **
