disable the CAD to close the call with the customer
Oct 14th, 2008
I have IPCCX 4.0(4), can i disbale the agent(CAD) to close the line during the call with customer from the phone.
ssoberlik Mon, 10/20/2008 - 08:50
  • Bronze, 100 points or more
Yes you can disable the CAD to close the call but you must be in the Not Ready state to make a call. The Make Call button is disabled when you are in the Ready state.
helawamry Wed, 10/22/2008 - 13:07
Dear SARAH
Thank you for your reply, but i need the desktop agent can't close the call with the client from the physical buttom under the phone set or from soft key end call.
l.mourits Fri, 10/24/2008 - 04:28
  • Silver, 250 points or more
Aha, the famous problem of trying to get a technical solution for misbehavior of individuals.
Answer is: There is no way to do this, other then taking disciplinairy measurements to your agents.
