trouble with admin of air controller 526
Oct 14th, 2008
I configured a 526 controller by connecting a PC to Port1 of the box. I configured the following three IPs: 192.168.1.250, 192.168.1.251 and 1.1.1.1 for the management, ap-management and virtual interfaces. When I have this PC connected to port1 I can ping, and manage it using the 192.168.1.250 IP. However, when I move the port1 interface to my CD500 network I can no longer ping or manage. I don't see any errors on the CE500? What's up with that?
Diego
PS: When the 526 is not connected to the CE500 nothing responds to pings on that IP so I am pretty sure it is not an IP conflict.
slongewa Wed, 10/22/2008 - 04:58
Is the port on the CE500 set to be an access or trunk port for the VLAN that contains addresses in the 192.168.1.0 Network? Does the 526 have a default-gateway set that allows it to access the network from which you are trying to manage the controller?
DIEGO ALONSO Wed, 10/22/2008 - 07:20
The port is configured as an AP port which is the recomended setting. Actually what worked was to turn off the auto mdi/mdx setting on the CE500 port. Been working well ever since.
Diego
