Amit Singh Tue, 10/14/2008 - 04:39
  • Cisco Employee,
I think its not possible with onboard fe interfaces which are l3 only. I havenot tried setting up the l3 etherchanne using the ports though...might be worth trying..
i know its possible with the use of Ether switchmodules on the router.
hipohoneywell Tue, 10/14/2008 - 04:46
When I issue the command "channel-group 1", the router says "channel-group 1 is not configure", which tells that somehow the channel can be configure.
Any help, please
glen.grant Tue, 10/14/2008 - 06:15
  • Purple, 4500 points or more
The command is probably there in case you have installed like hwic switch modules in which you can channel those interfaces .
