Hardware requirement for 4.1
Oct 14th, 2008
Presently the hardware details of the CCM 3.3 is as follows:
RAM-512
HDD-40 G.B
CPU- Compaq Proliant DL 320 server
1000 megahertz Intel Pentium III
Please let me know whether the same configuaration canbe used for CCM 4.1?
TIA
Overall Rating: 5 (1 ratings)
Rob Huffman Tue, 10/14/2008 - 05:44
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Vinay,
It looks like (from the attached Server Support Matrix) that this box would work if the Memory were upgraded;
Cisco CallManager requires a minimum of 1GB of memory on the Cisco CallManager servers. To avoid system problems, such as dropped calls, verify that your servers have a minimum of 1 GB of memory installed. If the installation process detects less than 1GB memory on the publisher server, the installation aborts. The installation process performs a similar check on the Cisco CallManager subscriber server; it allows the installation to continue if it detects less than the minimum requirement.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/4_1/cm413ins.html#wp532686
**Just as an FYI CCM 4.1 has been announced as "End of Life"
End-of-Sale and End-of-Life Announcement for the Cisco Unified CallManager 4.1
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps556/prod_end-of-life_notice0900aecd806f41d9.html
Cisco Unified Communications Manager Server Support Matrix
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
Hope this helps!
Rob
