VG224 and VG248 protocols
Oct 14th, 2008
Is this right that VG-224 can do only sccp protocol while VG-248 additionally supports SIP/H.323/MGCP ?
Anyway, product datasheets states actually these facts.
I'm interested in somebody's practical experiense to confirm this.
Thank you.
Overall Rating: 3.5 (2 ratings)
Jaime Valencia Tue, 10/14/2008 - 07:40
  • Cisco Employee,
  • Hall of Fame,
    2011
no, it's the other way around.
vg224 can be SCCP, MGCP, H323 or SIP, while VG248 is only SCCP
java
if this helps, please rate
Tobivan_Helden_2 Tue, 10/14/2008 - 22:44
Jaime,
Sorry, I confused. Thank you for your correction.
But my question is the following: is it PRACTICALLY true that the docs say ?
And if yes, why VG-248 can do only SCCP ? I mean VG-224 & VG-248 both run IOS,
but only VG-224 is able to implement a full range of VoIP signaling protocols ?
Jaime Valencia Wed, 10/15/2008 - 07:25
  • Cisco Employee,
  • Hall of Fame,
    2011
well, someone already provided the VG 224 data sheet, here is for the VG 248
Cisco VG248 Analog Phone Gateway
http://www.cisco.com/en/US/products/hw/gatecont/ps2250/products_data_sheet09186a008007c9bb.html
they DO only support what's on the sheets if that's wht you mean by "PRACTICALLY true that the docs say?"
i really cannot answer why VG248 can only do SCCP as i was not the one who created the product or had the idea behind it as to why only SCCP, most probably because it's proprietary and provided the most features and enhancement for analog devices
java
tony.parker Tue, 01/27/2009 - 13:43
Hi Tobivan,
The VG248 does not run IOS.
It is a much older unit.
Perhaps this is the reason
Cheers
allan.thomas Tue, 10/14/2008 - 11:08
  • Blue, 1500 points or more
Further to the good information provided by Java, below is a list of supported protocols on the VG224:-
PROTOCOLS SUPPORTED
• SCCP
• H.323v4
• MGCP
• SIP
• Real-Time Transport Protocol (RTP)
• Secure Real-Time Transport Protocol (SRTP)
• Trivial File Transfer Protocol (TFTP)
• HTTP server
• SNMP
• Telnet
• Dynamic Host Configuration Protocol (DHCP)
• Domain Name System (DNS)
• Cisco Unified CallManager 3.3.3 SR2 or higher version
• Cisco Unified CallManager Express 4.3.2 or higher version
• Cisco Unified CallManager or Cisco Unified CallManager Express redundancy support using Hot Standby Router Protocol (HSRP)
• Call survivability-MGCP failover to an H.323 connection to the SRST router
• Cisco fax relay, T.38 fax relay, and modem pass-through
• Coder/decoder (codec) support, G.711, G.729a
• RADIUS and TACACS+ for Telnet and authorization
Refer to the following URL:-
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/gatecont/ps2250/ps5516/product_data_sheet09186a00801d87f6.html
Rgds
Allan.
