2811 with ccp: discovery failed
drolemc Mon, 10/20/2008 - 11:46
  • Silver, 250 points or more
Normally it will take time to discover. In the Community Information screen, choose the device that you want to work with, and click Discover. Depending on network conditions, Cisco CP may take several minutes to discover the device. If you want to work with additional devices in the community, choose them and click Discover. To begin configuring a discovered device, click on the row for the device, and in the left pane, click Configure then the Configure tree expanded in the left pane.
In the Configure tree choose the configuration task that you want to perform.
