Not recieving the full bandwitch on T!
Oct 14th, 2008
Upgraded Frac T1 from 768 to full T1 1544.Sub interface shows 768k.The main interface shows 1536. Any suggestions on how to verify actual bandwidth so I can go back to the Telco Provider and make them fix? Thanks in advance.
interface Serial0/3/0
no ip address
encapsulation frame-relay IETF
service-module t1 timeslots 1-24
interface Serial0/3/0.1 point-to-point
ip address 172.16.0.38 255.255.255.252
no cdp enable
frame-relay interface-dlci 712
Serial0/3/0 is up, line protocol is up
Hardware is GT96K with integrated T1 CSU/DSU
MTU 1500 bytes, BW 1536 Kbit, DLY 20000 usec,
reliability 255/255, txload 5/255, rxload 245/255
Encapsulation FRAME-RELAY IETF, loopback not set
Keepalive set (10 sec)
LMI enq sent 8197, LMI stat recvd 8197, LMI upd recvd 0, DTE LMI up
LMI enq recvd 0, LMI stat sent 0, LMI upd sent 0
LMI DLCI 1023 LMI type is CISCO frame relay DTE
FR SVC disabled, LAPF state down
Broadcast queue 0/64, broadcasts sent/dropped 0/0, interface broadcasts 0
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 22:46:16
Queueing strategy: weighted fair
Output queue: 1/1000/64/0 (size/max total/threshold/drops)
Conversations 1/30/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1152 kilobits/sec
5 minute input rate 1477000 bits/sec, 133 packets/sec
5 minute output rate 34000 bits/sec, 75 packets/sec
7091337 packets input, 1226446220 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
4036622 packets output, 242804035 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
Serial0/3/0.1 is up, line protocol is up
Description: BellSouth NETVPN Service VRF
Internet address is 172.16.0.38/30
MTU 1500 bytes, BW 768 Kbit, DLY 20000 usec,
satish_zanjurne Tue, 10/14/2008 - 07:05
  • Silver, 250 points or more
rxload 245/255 already shows leaking is reaching to peak utilization.
Also clear the counter and see input rate & output rate, that will also give you fair idea,about throughput you are getting on this link
In addition you can use client-server application like "iperf" to test the bandwidth.
Jperf is the GUI for iperf.
HTH...rate if helpful..
johnlloyd_13 Tue, 10/14/2008 - 09:32
  • Blue, 1500 points or more
you consider the actual bandwidth on the main serial interface (s0/3/0). you may want to configure bandwidth on the sub interface (s0/3/0.1) and monitor bandwidth via a network monitoring tool or using show interface command.
