UCM6 database question
Answered Question
Hi Chaps, easy question
UCM6 - is it a SQL backend database that is used? if so - during a new installation is it possible to host the sql database on an external (corporate) SQL server?
Thanks in advance.
Rod
Correct Answer by Jaime Valencia about 8 years 7 months ago
no, windows versions use SQL, linux versions use informix.
cannot be hosted on any other server
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Tue, 10/14/2008 - 07:33
  • Cisco Employee,
  • Hall of Fame,
    2011
java
