UC520 Fax to email
Oct 14th, 2008
I am trying to configure a UC520 to email incoming faxes to users. I have an analogue fax machine that is currently connected to one of the FXS ports and operates as a normal fax. What do I need to configure to make this work, any pointers in the right direction would be greatfully appreciated
bwilmoth Mon, 10/20/2008 - 07:01
The configuration can be done by using fax passthrough instead of fax relay.On detection of a fax tone on an established VoIP call, the gateways switch into fax pass-through mode by suspending the voice codec and loading the pass-through parameters for the duration of the fax session. This process, called upspeeding, changes the bandwidth needed for the call to the equivalent of G.711.
ianwarb Tue, 10/21/2008 - 03:10
Many thanks
One of my problems that I haven't made clear is that I am using a SIP trunk for IPT connectivity and find that sometimes fax works and yet other times I get tx/rx errors. Do you know of anything I should be aware of delivering faxes over the SIP trunk
