problem ip phone 7912 series
Oct 14th, 2008
Hi everybody
I have a problem, when i connect a ip 7912 phone to a 10 base tx switch, i read phone display ethernet connect with a strange symbol,a telephon with a cross,and i can't ping the telephone and use it. Why?
Kid Dynamite Tue, 10/14/2008 - 08:28
Sorry... it says Ethernet disconnected? If so..
That means that somewhere along the line it is not communicating with the switch...
1) Faulty cat 5 cable
2) Faulty floor / switch port
3) Faulty port in the back of the phone
4) Faulty phone!!
1 of the 2 pairs in the cable is not getting through for whatever reaason, that is why you have got power but cannot ping / see it on the network.
ecoleather77 Tue, 10/14/2008 - 22:35
No i read on display i'm connected but i cannot ping it,infact doesn't work,i tried all port of switch 10base tx, but nothing..
Instead i i plug the telephon on switch 10/100 it works well, and the cross symbol go away.
p.s. I have another cisco that works perfectly on that 10base switch...
