Setup for Group in CallManager 5.0.4
Oct 14th, 2008
I am trying to setup a group so that when someone calls into my phone system and it is answered by Unity, users would dial 6 and it will call a hunt list which is 600 to ring through a couple of phones for Technical Support.
Overall Rating: 5 (1 ratings)
tim.giles Tue, 10/14/2008 - 09:09
  • Silver, 250 points or more
Are you familier with call handlers and caller input?
Basically, you can create a caller input on this subscriber account (for keypad 6) which forwards onto a call handler.
Then you could configure the handler to forward out to the hunt pilot configured in CallManager?
Caller input configuration:
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/403/administration/guide/ex/SAG_0170.html#wp1149904
Call Handler configuration:
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/403/administration/guide/ex/SAG_0200.html
Please rate useful posts...
nshoe18 Tue, 10/21/2008 - 13:19
So I created my hunt pilot. Internally I can call the extension, 600, that I setup for the gruop and it will ring through all the phones in the group. When I try to create the handler, I cannot get it to forward properly.
Jaime Valencia Tue, 10/21/2008 - 18:56
  • Cisco Employee,
  • Hall of Fame,
    2011
configure caller input to attempt transfer to X handler, on the handler itself configure the transfer options to "yes, ring subscriber at this extension"
java
if this helps, please rate
tim.giles Wed, 10/22/2008 - 02:21
Yep, as per Java's last comment, this should do it! 5*
..let us know if you have any more problems.
nshoe18 Fri, 10/24/2008 - 11:54
Ok, I setup to the call handler to ring the subscriber's extension but it does not seem to be transferring from Unity to CallManager. I have set this up previously for the Operator to a group and it works. I am just confused. Maybe I will start from the beginning and rebuild it.
